I just got a message stating my Red Brick battery was incompatible. I'm getting this message every time I boot the camera up. It's an Epic Dragon running 5.3.29 firmware. The only thing I can think of is I'm using a WC V-Lock battery plate. Anyone else seeing this?
The problem just went away. Probably with firmware updates. I haven't seen it again. If you're getting that w/ all Red equipment, you should probably file a ticket.
