Importing r3d issue
Simon Buxton
Hi All,
Premiere Pro 6.05 with a freshly installed R3D converter
Hopefully you can help :)
My library structure of source files for my currrent project is the following:
RED/ A0xx_xxxx.RDM/A0xx_xxxx.RDC/A0xx_xxxx.R3D
If i try to import the entire root folder (RED) then I lose about 50 % of the files (deemed to be 'unsupported format or damaged file'). However those files that are supposedly corrupted open just fine in RED CINE-X and also open fine in Premiere if i open the RDM's individually.
I assume that I cant be the only person experiencing this but i cannot find another thread on the subject. I also had an instance of CC running on the same computer (which does not seem to want to deactivate itself) and this also has the exact same problem.
Any help greatly appreciated
