- Banned
- #121
OK. I have to eat crow. I admit it. I won't just shoot 4K.
Shooting 2K windowed is a completely valid option.
1. Even windowed from 4K, the 2K sensor portion is larger than 2/3", better DOF characteristics than an F23, HDCAM or Viper.
2. Having 72fps (for now) at this frame size is better than HDCAM-SR 4:4:4, which now shoots 60fps at 1080P.
3. You can use all your 35mm PL mount lenses, except at the wide end due to the focal length factor. You'll need a wide S16 lens or two to cover all the bases.
4. The record time to 8GB CF is over 20 minutes.
5. Pushing the data through the pipeline is much easier.
And best of all, the image looks great.
I still will shoot most of my stuff 4K, but I won't hesitate to shoot 2K windowed if necessary.
Jim
O.K.
This is what I mean about cherry picking. See above.
1. This is probably not true. Yes you do get 35mm DOF that
part is correct but at the cost of image quality. the F23 will
produce much better pictures than Red in 2K windowed mode.
It has three 2/3" sensors.
2. 72fps at what cost? If picture quality is going to be less than
a D20 or F23 recording out to HDSR 444 that's no advantage.
3.Yes you can use your 35mm PL lenses but you'll have to fork
out megabucks for Zeiss wide primes and zoom. And have two lens
sets on the shoot.
4. I'd much rather have a 10 minute record time at 2K scaled.
1000' film mag is 10 minutes. This is never a problem.
5. That may be so, but again at what cost. This camera will be
used by some in 2K windowed mode to do high speed work for
a digital super35 2.35:1 feature production.
My concern here is that this footage, these frames, will look
like mush when intercut with 4k raw originated material in a
typical multi generational film finish.(not a high definition finish)
If nobody else here thinks this is a concern then I'll shut the F up
Have a nice day all. Yours, Mezmo
