How to simulate: Fire illumination, Pyro Effects, Living room on fire
Daniel Reed
SF Bay Area
www.nextbooth.com
Greetings,
I'm researching options/methods for creating the illusion of parts of a living room appearing on fire as a dialogue scene with talent on a couch.
We obviously will not be setting a living room on fire :mad5:
Think Barton Fink, Syndoche NY
Please see my better detailed post on the cinematography.com forums:
http://www.cinematography.com/index.php?showtopic=71850
Thank you for any and all advise/guidence
Thanks Lakis; however, I prefer to employ as much physical practical effects for this as can be mustered.
cool, thanks Mark!
Magic Gadget appears to make a popular flicker dimmer
I've never worked w/ a flame bar, and frankly feel a litle intimidated by it
I've put candles underneath and in front of lenses before(out of frame),
not for the flame, but for the warping heat effect - thought about doing something like that
beside making my own fire plates, purchasing pre-keyed fire assets is an option such as:
http://www.detfilms4k.com/fire.html
Illumination part: cut the orange color gel into a striped curtain and have someone shake it in front of a strong light source. Usable depending on the fire light effect you want to achieve.
David, that's a very cool idea! Thanks for the tip!
David's idea got me thinking about front projection...
film a hot set, do effects work on it, project via a one way mirror during actual.
I suspect front projection may not work well with haze filled sets - thoughts?
If using plain glass, or making your own oneway mirror, is low-iron/starfire glass the way to go?
I found this place for custome glass work: https://admglass.com/
I've taken a 6x6 of gold lame' and loosely draped it, the gold side facing the subject you want to illuminate. Shoot a tungsten source into it, and have somebody give it (the gold lame') a gentle movement, and the flickering bounce off the fabric approximates fire well enough.
...This obviously only for the illumination part of the challenge.
Interesting suggestion, Nathaniel.
Is there a specific brand/source of lame' fabric that worked best for you?
I imagine i can pretty easily hang a sheet between two cstands,
point tungsten lamps at it on flicker dimmers,
and then have just one person give the sheet slow/gentle movements
Have had very good results with flicker boxes and tungsten instuments with red and orange party gells for the effect of off camera flames. I like using 3 or more flicker boxes, all slightly off form one another. Smoke and haze helped a lot. beware that this can set of a smoke alarm
For anyone interested, here's a write-up I found by Andrew Davidhazy about front projection:
http://scholarworks.rit.edu/cgi/viewcontent.cgi?article=1439&context=article
