How to remove Scratch LOGO from 2nd monitor when not in use?
Lou Cann
Active member
Hi All,
Been trying to use the scratch player to view my ProRes clips and use it in replacement to quicktime pro.
However, it uses both monitors regardless if I toggle dual head output. So my only choices are to use dual monitors or have a logo on the other.
This is annoying since I can not have any other programs side by side.
Just wondering if there is a magical switch to kill that 2nd monitor?
Thanks,
Lou
Hey Lou,
please connect with support@assimilateinc.com.
If you disabled "Dual Head" in the Play Pro Settings, the second monitor should not be used at all and just display the desktop or whatever you want to put there.
Mazze
