Roger Valdes
- Oct 29, 2012
I'm curious if itd be possible to record very high framerates at high resolution onto a ram drive? Similar to how the flex works. RAM has a much higher bandwith rate than Flash, so 4k at 1000fps should in theory be possible if the sensor is capable enough.
