Hi redusers!
Quick question about mastering our project in HFR 60 frames per second or 59.94 frames per second. Below I will elaborate a bit on our project.
For a videowall installation we're combining 168 LED Panels to display a video with a total resolution of 3840(width)x6480(height). We'll master in H265@60fps.
The HFR presentation will guarantee a judder free presentation to the audience, who'll be standing very close to the videowall. Thus minimizing motion artifacts.
The videowall uses LG WS50 Display Panels. Playing at 60hz.
We're combining 5k and 4k Red Epic footage with lots of animation. Most of the footage is shot with a 59.94 fps timebase. But some footage is shot with a 25 fps timebase.
For our post-production workflow I was wondering if I should interpret all 25fps footage to match the 59.94 fps shots, and master in that frame-rate?
Or should I go for a true 60 frames per second master? Interpreting both the 25 and 59.94 fps shots to 60 fps.
Since the master will be played from a computer there isn't a broadcast standard to comply to. And we might be able to simply playback a true 60p master.
Or would a display like the LG, playing at 60hz, still require a 59.94 signal to operate properly? They're connected through dvi. (Clustered in groups of 4 screens, each receiving a 1080p60 signal).
Thanks in advance for your input! It's quite a challenging project. But the HFR playback looks awesome. Specifically in combination all the animated objects. So smooth!
