Rodrigo Prata
- Nov 9, 2009
Hi, Im having a few concerns about this setup I`m using:
I`m currently using a Epic-X and a +1 Adaptor Module and a Pro I/O module.
There seen to be a bad contact on the +1 one lemo connector, because every time someone touches the cable, the monitor (or EVF) attached to it freezes and it wont come up unless I shutdown the camera. It happens the exactly same thing with the Pro I/O module.
The +1 Definitely have a problem because even without the Pro I/O module, it presents this bad contact problem, so is is it possible that the problem is just the +1 and that it translates to the Pro I/O module ? it seen a bit improbable that both modules would present the same exact problem.
Also, can I use the +1 attached but with the HDMI connector unplugged? so I can use the Pro I/O module and still have an HDMI output from the brain?
Thanks very much!
Thanks very much!
