Help! Smallhd 702 “no signal” when plugged into dmsc2 I/o
Jason beaumont
Miami
Tried it with another monitor , also no signal.
Tried monitor on another hdmi device, works fine.
Either the hdmi port on my I/o went bad or I’m missing a setting to make it compatible , it’s worked in the past. Any ideas
Not sure if this is the issue but the side pogo of the DSMC2 body shares the same port as the SDI port. So if you have a RED LCD monitor mounted on the side, the SDI won't work.
