Help Powering Litemats spectrum on battery
Montreal, Canada
Hello,
I just got an order of Litemats Spectrum 1 and 2. I also got a single gold mount battery plate to PL4 to power those litemats on Battery. My question is: How would you power such a light off a gold mount battery? What would be the minimum requirements of that battery to be able to turn on the light? I know it is possible since the accessory is sold by Litegear themselves in order to power the Litemat 1 and 2 Spectrum via a single Gold-mount battery...
I'm asking since I tried using a 160WH 14.8v and the light won't turn on. (I would use those batteries to successfully power the Litemat 1 & 2 bicolor PLUS versions)
Here are the litedimmer spectrum specs: (I feel like it's missing output current info. AKA: Amperage required for the light to work)
SPECIFICATIONS (IMPERIAL/METRIC) POWER RATING: 200W Nominal
VOLTAGE INPUT*(BATTERY):
10~35VDC (PL4 Connector)
14.4 VDC Nominal (One Battery) For LED Loads up to 100W
LINK FOR THE DIMMER AND LIGHT Document center: https://www.litegear.com/document-center/
(Find Litedimmer Spectrum user guide)
Thank you for your help!
