walid kafi
Active member
Hey guys,I've been a c100 shooter for quite some time and I will soon have enough for an epic. Now I know I won't be able to use my current pc for red raw editing/coloring. I will be using primarily Premiere CC and Speedgrade CC.
I have made a list for my new upcoming Pc:
Corsair Carbide Series Air 540 (CC-9011030-WW) Black Steel / Plastic ATX High Airflow Cube Case
ASUS Rampage IV Black Edition LGA 2011 SATA 6Gb/s USB 3.0 Extended ATX Intel MotherboardIntel
Core i7-4930K Ivy Bridge-E 3.4GHz LGA 2011
2 x EVGA 06G-P4-2791-KR GeForce GTX TITAN SuperClocked 6GB 384-bit GDDR5 PCI Express 3.0 x16 HDCP, SLI Ready Video Card
NVIDIA® Quadro® K2000 VCQK2000-PB 2GB GDDR5 PCI Express 2.0 x16 Workstation Video Card
areca ARC-1223-8I-MS PCI-Express 2.0 x8 Low Profile SATA / SAS RAID Controller Card
CORSAIR AXi series AX1200i 1200W
Evercool HD-AR-RBK HDDCooling Box for Three 3.5 HDD
2xSAMSUNG 840 EVO MZ-7TE1T0BW 2.5" 1TB SATA III
G.SKILL Ripjaws Z Series 64GB (8 x 8GB) 240-Pin DDR3 SDRAM DDR3 2133
5xSeagate Barracuda STBD3000100 3TB 7200 RPM SATA 6.0Gb/s 3.5"
CORSAIR Hydro Series H100i
2xASUS - PA249Q 24" LED Backlit IPS
Now I got a few questions:
1. How do I set up the GPU's within the motherboard to take advantage of the the dual titans SLI and quadro for premiere and speedgrade.
2. Do I plug both monitors on the quadro to take advantage of 10bit or do I plug one monitor on the quadro and one on the titan??
3. Is the Raid controller I chose good for internal AND external raid configs?
4. which RAID level would be best suited for this pc?
5. Is dual titans overkill??
Thank you in advance!
