Help! Accidenty disabled menu on monitor (non touch)
Help. I accidentkl disables menus on my red monitor (non touch). Is there a way to hard reset? I only own Sidehandle. Thanks...
Im on a shoot and desperate.
- If you are running 3.2.x you can reset to factory defaults using a long (>15s) power hold on startup.
- Perform a force_upgrade will also reset to factory defaults
- There are a set of force_preset files in the DSMC RESOURCES package available on red.com/support that will set the menus to either HDMI or HDSDI - you could use one of these and use the external monitor to re-enable menus on your lcd.[h=3][/h]
