Chris Angelich
After using my S35 Helium for a month and mostly shooting in 4K, last week shooting in 6.5K on each clip there was a vertical string of 'hot pixels' always in the same area of the sensor. I am attaching two .jpgs to show the pixels.
What is the procedure to fix/correct this?
Should I restore the firmware to the deffault original state .. then upgrade to the latest firmware?
Should I do a sensor recalibation and if so.... manual or automatic?
If these two steps will not correct the issue is there a Red email addy in support to send the jps to somthey can suggest a fix?
Thanks!
Thanks!
