Brigham Edgar
First of all, tried searching but no direct answer.
I just returned from a shoot using a 8inch SWIT HDSDI 720p monitor for client monitoring and has some interesting problems. The monitor was constantly dropping out and could not get the signal from the RED constantly. Also, the only way to even get a signal at all was through 59.94HZ instead of our native 50HZ here in Australia. This also was the same when connecting the HDMI output to a monitor as well in the past. I scrolled through all the setting trying to rectify but no luck. Monitor just wasn't getting the signal constantly. Tried different cables etc.
I'm still running build 15 2.25 if this helps.
