- Moderator
- #1
Jeff Kilgroe
OK,
I had been blissfully using the new RocketCine-X and playing with REDCINE-X since the new ones were released 2 weeks ago. But I had not run them to my plasma -- had it on a different system for use with the Kona.
As soon as I connect the plasma via a DVI to HDMI cable and select 1080p, I can only set the Rocket to 8bits. I knew this was the case before and was hoping that we would eventually get an update for 10bit or even 12bit HDMI support.
Deanan, Stuart, Rob... Anyone at RED care to give us an official answer about support for 10bit+ color via HDMI on the Rocket? Can we just get a "yes" or "no" as to whether or not it will happen?
If the answer is "no", would it be possible to ask why?
