Jose Lomeña
- Dec 28, 2006
Quick review about HDLINK PRO 3D
My Setup:
2x REDONE Beta31
1x AJA GEN10
1x HDLINK PRO 3D Display Port V3.4
1x Samsung Led 3d7000
1x Cable Converter Display Port to DVI
1x Cable converter Display Port to HDMI
The only way that it work for me is:
Use converter Display Port To DVI and to DVI input of Samsung. (HDMI converter didn't work)
AJA GEN10 is essential. Without it all time one camera only (SDI 1)
All working now, and I can see 3D with my setup.
Problems:
1. Resolution output only 1280x720 side by side. No 1920x1080. Big deception.
2. 50Hz output is bad. A lot of artifacts. You need to out 59.97 from red.
3. When you play a clip with red it work, but when exit from playback you need to reset gen10. And push 3d mode in samsung.
4. Some times HDLINK go black and return after 2 second. In this case you need to push a new time 3d mode in the samsung because a fault in the signal. This is the worst problem.
5. You can't use Luts of HDLINK to only one camera.
My recomendation:
Don't buy HDLINK PRO 3D for 3D with REDONE... it work perfectly with only one input, but both input is a continous problem.
I have other system TVONE 1T-C2-750. This is what i can do with it:
2x DVI (digital or analog component) inputs. No SDI input.
1x DVI output (digital or analog)
720p or 1920x1080 50p out side by side with redone at full screen (open gate work perfectly)
Possible to move horizontal or vertical one or both cameras
Possible to zoom or flip.
10xPresets
Perfect with 50Hz or 60Hz. No artifacts.
No delay. No fan. No hot. 12v power. Small like HDLINK.
Buttons, you don't need a computer.
You don't need Gen10
Always output is stable. No problem with samsung
I think that anagliph is possible. (i didn't test it because i don't need it)
Price 800$
Note:
I don't work for AJA, DECKLINK, TVONE or RED. I'm only an end user and very disappointed with HDLINK 3D.
Saludos,
Jose Lomeña.
My Setup:
2x REDONE Beta31
1x AJA GEN10
Problems:
My recomendation:
10xPresets
Price 800$
Note:
Saludos,
Jose Lomeña.
