Has build 16 improved audio?
Mark B.
48
Are the phantom power outputs working now?
Audio status in Build 16
[QUOTE5]Are the phantom power outputs working now?[/QUOTE]
No change in status of phantom power, but yes other audio improvements ..
Hi Stuart,
Are you able to elaborate on the improvements? I have read posts concerning Red's audio performance and also the Sound Devices review (I own the sound devices 722 - beautiful bit of gear).
I have been considering buying Red for some time but as I do documentary work the camera's capacity to capture usable audio using the microphone inputs is pretty important to me (though I do go line level in and capture double sound whenever possible).
Rob
PS my first post and I hope to be ordering RED soon.
Hi Stuart,
Rob
I need exactly the same from the other reason.
Audio on RED is fine.
By the time you will get your camera you will not need this phantom power cables, I think.
Here is the sample recording from 5' distance with the phantom power ON.
http://www.reduser.net/forum/showpost.php?p=223759&postcount=8
remember to right click.
So it seems that the camera "should" have phantom as it's an option in the menue and all other professional cameras do have it...when??
I have an issue with audio on the recent 16 build. I get a tone for audio on channel 1 and 2. Channel 3 and 4 don't work at all. Is this a known issue? Is there a fix?
