I am trying to buy a Gitzo tripod to support a O'connor 1030D head with a 100mm bowl.
In fact, I own a Gitzo GT3541XLS + Sachtler DV6SB combo with 75mm bowl. I love how versatile it is with height. I can go super low and super high with one set of sticks. However, I feel the range of leveling adjustment a bit limiting. I only have less than 10-degree of movement on the bowl (my guesstimate), due to the rather small top ring of the series 3 design, where the bowl adapter ring sits on.
Although I don't have access to actually try it out myself, I can imagine a 100mm head will only have LESS leveling adjustment than my current 75mm combo. That will render the use of the bowl a moot point.
Can anyone verify this?
So do I have to move up to a series 4 or series 5 tripod to gain a wider range of leveling movement with a 100mm bowl?
I am not even sure if a series 4 tripod is an improvement over series 3 because they seem to share the same size of top plate (right?)
That will left me with only one option: the Giant GT5562GTS. With a max height of more than 9feet / 2.8m, it may be more sticks than I need.
I also like Miller's solo sticks - if only they would go as low as a Gitzo.
Suggestion? Idea? Experience to share?
