Gioscope: 2nd and 3rd do nothing (on DSMC3 monitor)?
Janis Huber
Hello
I've been playing around with Gioscope. I figured: 2nd and 3rd show NO color on the DSMC3 monitor even when turned on (and 1st turned off to confirm). Only 1st. However, on the onboard LCD 3rd shows color (while on the DSMC3 there is just grey). 2nd both on the LCD and the DSMC3 monitor shows NO color. Anybody figured this? Is this a bug?
I'm on the latest firmware for both KX and monitor. But whats odd is that on the Internal Top Monitor I see 3rd color while not on the DSMC3, and - as described - nothing on 2nd. I will try different configuration, but in my logic that makes no sense and seems like a bug.
Have you tried if it works on the SDI out or in combination with Red Control App?
I'm asking because I was only able to test with the onboard LCD and SDI and the app. With the app I set Top-Port as source for the livestream.
What I've noticed for LCD, SDI, APP is, that it maybe difficult to distinguish if 1st, 2nd and 3rd are all visible. Especially on a 7" screen depending on your scene. If you switch on and off 1st while 3rd is always active you may notice a change / increase of "lightness" of 3rd when 1st is active.
Have you checked the DSMC3 for the latest firmware as well?
Check the latest 2.1 firmware update​
SIGNIFICANT CHANGES SINCE KOMODO-X 2.0.9​
  • Added continuously variable ND control
  • Improved lens compatibility
  • Fixed GIO Scope
  • Fixed possible 4K SDI issue at boot
  • Fixed Broadcast Lens control with non-PL lenses
