Gini Rig RED Pro Kit Questions
Bryan Gosline
New member
Hi. I'm curious if anyone owns this handheld rig? http://www.ginirigs-usa.com/89-pro-kit-for-red-scarlet.htmlmy concern is that I have the vmount on the back. As the photos show, I don't know if the rails would fit above the battery on the back of the Scarlet. Any clues? Thanks!
I've attached what my battery setup is like, am I wrong?
Well, a Red brick battery is definitely too wide to fit between the rods of even a 19mm rods system, and those rods don't look quite high enough to to clear the top of your battery (although can't say for sure without measuring - why not contact the seller direct to measure it for you?). But this isn't unique to the Gini system.
You'll probably either have to use short rods for the front only, or find a different battery mounting position if long top rods are essential for you, or find a way to raise the top rods still further.
Thank you! I've tried contacting Tom from Gini Rigs many times, and with photos - no answer. Granted it's only been 12 hours or so.
I appreciate your response!
did you find any info on the rig Bryan?
