GEMINI Sensor Temperature ISSUE
Edy Martinez
Fort Worth TX
Yesterday my Gemini get crazy Hot mostly was in
57/57/ or 60/60 with the "T" on red color, my Fans was on 39. Adaptive mode, & the temperature of my office was on 66 Fahrenheit i just leave the camera warm up like 30 minutes & never change the sensor temperature.
im upgrade the firmware & see if that would works but noting change.
I decide to run a Blackshading on this temperature 57/60
i know is to bad but at least i get back the "T & E" on green.
Any way o shot some test here is the link below if you guys want take a look, if would be safe to keep the sensor on that temperature?
Any advice let me know
Thanks!
Footage was shot on:
ISO 800 Std & 1600 & 3200 LL
Lens 50mm 2.0F
http://www.reduser.net/forum/attachment.php?attachmentid=122355&stc=1&d=1586714066
Footage: https://we.tl/t-ewUhdMXlAU
Edy Martinez
2430norte@gmail.com
IG: edymartinezdp
www.2430nortefilms.com
I also had a similar problem with Gemini, but it was a day in full sun and very hot.
I think I also detached all the modules. I do not remember........
I think I reset the whole camera, canceled all the blackshading and made a manual 180 degree shutter at a temperature of 42-43 degrees.
Does this problem do it both connected to the power and to the battery?
Hey Luigi, the issue is on it no matter if i use the Battery or DC Power, how do you fix it?
Edy
If the "T" indicator is going red then you're out of the recommended temperature range and may have issues.
It's probably worth submitting a ticket at support.red.com to run a log file by RED.
