G-Tech Red Mini Card Reader not mounting
Tim Bonython
Active member
Sydney, Australia - Northern Beaches
www.surfingvisions.com
I am in Portugal and just done a shoot with a big day in store tomorrow.
I am miles away from anywhere.
Simply my G-Tech Red Mini Card Reader will not mount.
Tried everything. So can i download from my Epic Weapon camera? Any help would be greatly appreciated.
Kind regards
Tim Bonython
To answer the second question, there is no way to use your Epic as a card reader.
For the G-Technology Mini-Mag reader, check through every possible failure point step by step.
Check to make sure the USB 3 port on the reader is unobstructed, try alternative cables, use different USB ports, use a different PC/Mac.
Recently, I had a small piece of tape get stuck inside the mini mag chamber which prevented the mini mag from fully inserting into the G-Tech reader. I've also had the common problem of not enough USB power to the device.
Best of luck.
-A
Hi Tom, I had that problem a few months ago and I posted it on Reduser. My problem was the G Tech Mini Mag reader itself, you may have a faulty one, I ordered one from Red and I sent back my G Tech Reader to B&H for a replacement. I now have both options and they both work perfectly.
