FS: Quick release Bridgeplate for 19mm rods + 12" Rods - Arri and Red One compatible
Peter Gosens
Active member
Amsterdam, The Netherlands
www.petergosens.com
The quick release bridgeplate is compatible with Arri camera's and the Red One. For other Red camera's you need an additional lifter. It goes for 299 euros.
12" Rods 19mm go for 25 euros each.
Have a look at my website www.petergosens.com to for more info. I also got 12" dovetails for sale.
Just to make things a bit clearer.
- For Arri 16mm and 35mm camera' s you don't need anything.
- For the Arri Alexa you need a plate that already comes with the camera.
- For the Red One you don't need anyting.
- For the Red Scarlet and Epic you need an additional bottom plate. Several brands make them. Like the one hinted by Kemalettin earlier before.
You can also use it as a more heavy weight rods system for your big zoom lenzes on the Canon C300. For this several options are possible. It depends a bit on your excisting camera support system. Just send a PM if you want to know more.
Just a small update on the compatibility. In essence its just an Arri BP-8 and Red One bridgeplate in one.
Compatible with the Red One, Arri Alexa Studio, Arriflex 235, Arriflex D-21, Arriflex 435, Sony F23 F35 F65, SI-2K, Phantom and Weisscam HS-2.
Arri Alexa or Alexa Plus only with Arri’s own bridgeplate adapter BPA-1 (you get it with the camera).
Red Scarlet and Epic only with a riser plate, available from several third-party manufacturers. As mentioned before.
