George A.
- Apr 11, 2007
- New York City, NY
- www.eastrentals.com
Hi!
We've moved up to EPIC and so we are selling out beloved RED ONE PRO 7" LCD.
We've had this wonderful monitor for a couple of years now and it has served us really well!
Selling for only $1,300 (reduced).
We are selling for a rather low price because it has a small scratch in the bottom part of the screen... it has created no problems whatsoever as far as the operation of the LCD is concerned, we even rented it out a few times and no one had any concerns. When the LCD is on, you barely notice the scratch - please see the attached photos for reference.
The screen is a pleasure to work with, much comfortable and accurate than the original 5.6" LCD - in fact, there's no comparison between the two screens.
See the pics below - for honesty's sake, we took pics of the LCD both turned off (you notice the bottom scratch) and turned on (you barely notice it - it doesn't impend on the operation of it in any way). Other than that, just the normal wear and tear on the casing and the coating, after two years of use - same as with any other two year old PRO LCD out there.
We are also throwing in a short LCD Arm which is a bit loose - we don't have the time to look into it but if you disassemble it you most surely can tighten it back up to where it should be. Usable as it is anyway, just a bit too loose for my taste.
So, if you need a PRO 7" LCD for your RED ONE, drop us a line at:
eastco@gmail.com
Thanks for looking!
George
P.S. If you are in New York, you are most welcome to come and check it out.
eastco@gmail.com
Thanks for looking!
George
