FS: Panasonic BT-LH900a 8.4" HD-SDI monitor w/ waveform. Includes custom Case.
Michael Totten
Los Angeles, CA
Monitor is used but is in good working condition. I purchased brand new for $5,500 about 5 years ago.
Comes with a custom ATA case designed by Charlie at master cases (gray with black stripe).
Will consider any reasonable offers. Located in Los Angeles (would prefer to sell local but will ship if necessary).
If interested please email your offer to at: michaeltotten at mac dot com
I will respond promptly.
Here is a description of the monitor and it's specs:
DESCRIPTION
The Panasonic BT-LH900A 8.4" LCD Monitor represents the ultimate in video assist technology, able to handle the complete range of SD and HD formats. Packing an ultra high resolution panel into a modest lightweight frame makes this unit the prefect complement to any serious production.
Top-end features, such as high quality image reproduction, waveform monitoring in 16:9 mode as well as a built in CineGamma function when coupled with Panasonic's acclaimed Varicam camera, only scratch the surface of this highly versatile monitor. The LCD is light enough to mount on top of any ENG camera, as well as smaller units without sacrificing functionality. In addition to its wide array of features, the BT-LH900A can also be mounted in any standard rack system side by side using the BT-MA900 rack mount.
Format Compatibility
The BT-LH900A handles almost any format in standard or high definition and can be customized to switch between them automatically. There is no flipping a switch, accessing a menu, or turning a knob. Simply set the monitor to AUTO and the LCD will do the work.
Detachable Control Panel
The LCD has a detachable control panel, enabling it to fit in virtually any area. Attach the controls to the bottom or right side; wherever fits you best.
Waveform Picture-In-Picture
In 16:9 mode, the LCD will display the input signal as a waveform image. This can be vital for proper color correction and white balancing, especially when conditions make it hard to calibrate by eye.
CineGamma Function
The included CineGamma function, specifically designed to be used with Panasonic Varicam High Definition Camera, provides the camera operator with precision color reproduction.
High Viewable Angle
A 170° vertical and horizontal viewing angle ensures that you can continue to view the LCD no matter where you are. This can be useful during productions where space is limited.
SPECS
Video System NTSC and PAL
All HDTV Formats and Frame Rates
Application Field Monitoring
CRT Size 8.4"
Maximum Resolution 1024 x 768
Viewing Angle 170°
Color Temperature Pre-Sets 6500k, 9300k
Input and Output Connectors SDI Video- 2 lines, BNC x 3
Component Video- 1 line, BNC x 4
Composite Video- 1 line, BNC x 2
External Power- 4-Pin XLR
RS-232C Control- D-SUB, 9-Pin
GPI- D-SUB, 9-Pin
Battery Mount Anton Bauer
Power Requirements 12 VDC (11~17V)
Power Consumption 22.8W
Dimensions (WxHxD) 8 9/16 x 6 15/16 x 2 7/16"
2.18 x 17.6 x 6.5 cm (equal to 4RU)
Weight 4.4 lbs
2 kg
And a couple images:
