[FS: GEAR] FS: Nauticam Underwater Housing form Red DSMC2 Cameras
Chris Tallo
New member
If you have ever wanted to shoot a red underwater then this is the underwater housing for you.
I have owned this housing for about 2 years.
Recently, sold my red and do not have a need for this housing.
It was easy to use and very easy to set up.
Lens, focus/zoom gear and port changes are VERY easy. Takes just a few minutes.
The full red functionality is available to you through the housing.
The housings retails for about 12K
This housing will come with lots of extras
-top handle makes carrying in and out of the water easier.
-trim weights to adjust buoyancy
-SKIDS allowing for the attachment of lights and other accessories.
-SDI bulkhead for an external EVF
-Vacuum value to provide insurance against leaks
-Monitor back compartment for viewing the 4.7 redtouch from the rear of the housing.
-Solid back compartment for attaching two batteries
-Wooden Camera cable to connect monitor to brain.
This package sold new (check reefphoto.com) would cost about 15K
I am asking 9,999.
You can see pictures of all items mentioned above at https://christallo.store
