FS: DJI RONIN 2 Pro Combo - Bundle with Ready Rig GS Stabilizer with ProArm Upgrade
Neil Abeynayake
DJI RONIN 2 Pro Combo - Bundle with Ready Rig GS Stabilizer with ProArm Upgrade​
We are also, open to sell the RONIN 2 and the Ready Rig GS Stabilizer separately for those who are interested.
We are selling a newly purchased DJI RONIN 2 professional gimbal with a bunch of optional accessories. We used the gimbal only once to make an 8K feature pilot. Again, we ONLY used this one, indoors for two days. As a result,we are currently in production of a multi-episodic series for a major streaming provider who has their own on-set, Techno-Cranes, gimbals and camera-cars, etc, at our disposal. So, this gem is sitting comfortably, unused, in our in-house, climate controlled equipment storage room. This unit comes as a professional combo paired with a Ready Rig GS with Pro-Arms upgrade and a bunch of optional accessories worth over US4600.00. Every one of those optional parts were purchased on recommendations by our DP/camera crews for operator comfort, ease of use and functionality on-set.
You may find RONIN 2's offered at lower prices on eBay. There possibly are many reasons for these: such as,stolen, dropped, water-damaged, abused, with missing or damaged parts, rentals, used over large bodies of water on boats (Ahem!...... saltwater spray), used in desert environments (sand & dust) etc. Our device was handled with extreme care, kept indoors at all times and never left the studio premises.
Listed on eBay for 9,350.00 and Offering this combo for REDUser members at $8750.00 for the combo and everything that is listed here. We are open to reasonable offers. NO LOWBALLERS please.
Local pickup available in Long Beach, CA. We encourage you to personally test before purchasing, if need be.
Those who prefer to purchase through our eBay account, here's the link:
Ronin 2 exists to let filmmakers capture the scene they see in their mind. Upgraded high torque motors allow it to support a wider range of cameras, resist high winds and G-forces caused when mounted to a car and keep it moving smoothly in flight.
Intelligent
Enhanced intelligence means filmmakers can get shots with Ronin 2 that would once have needed specialist expertise or additional equipment, from total smoothness control to studio-oriented smart features.
Integrated
Power systems are now tightly integrated into Ronin 2, capable of powering its motors and the attached camera and accessories without dangling cables or multiple power systems. As it uses a dual battery system, filmmakers can hot swap to keep the camera and accessories powered and maximize shooting time.
Most versatile professional 3-axis stabilization system
Monocoque carbon fiber frame design
High torque motors supporting cameras up to 30 lbs
Fine tune balancing for precision control
Self-heating hot-swappable batteries
On-board power for camera and accessories
Integrated camera controls
Built-in GPS & compatible with DJI A3 Flight Controller
DJI RONIN 2 Remote Controller with Camera On/Off functionality.
Comes with:
Gimbal
Grip
Remote Controller
* 6 x TB50 Intelligent Batteries (This unit comes with 2 batteries and we purchased 4 more that's included in this package. This gives you uninterrupted power for the RONIN 2 gimbal, camera,monitor, follow-focus motors and more for unlimited time, i.e. if you keep depleted batteries charged when not in use)
Dual TB50 Battery Mount
* 2 x DJI Battery Chargers (You can charge up to 8 batteries simultaneously)
* 2 x Quad Charging Hubs
* 2 x Battery Charger Power Cables
Ronin 2 Power Hub
Protective Case
Camera Top Cross Bar
Camera Base Plate
Accessory Mount
15mm Focus Rod Mount
Ronin 2 Universal Mount
Top Mounting Block
MotionBlock
ARRI ALEXA Mini Power Cable
ARRI ALEXA Mini Start/Stop Cable
RED Power Cable
RED RCP Control Cable (Start/Stop)
* Wooden-Camera External Monitor Cable for RED Cameras
* Monitor Mounting Accessories for External RED Touch Monitors
* Monitor Sun Shade for RED 4.7" Monitors
Ronin 2 Power Cable
2-Pin Power Cable
DC Power Cable
Triple D-Tap Breakout Box
SDI-In Cable
SDI-Out Cable
USB Type-C Data Cable
UART to D-BUS Cable
* 2 x CineMilled Upper Tilt Arm Extensions for DJI Ronin 2 Gimbal (These allows you to mount larger broadcast or cine type cameras to the RONIN 2)
* RONIN Tool
* 2 x 15mm 8" Aluminum Rods
* READY RIG GS STABILIZER with ProArms extension (The Ready Rig GS + ProArms features vertical stabilization and reduces bounce motion, providing smoother camera control.
By redistributing the weight of a gimbal-mounted or handheld camera setups to your legs and core, this kit enables you to extend your shoot for longer periods of time with less fatigue. The Ready Rig GS + ProArms works with any gimbal in standard or underslung mode or a handheld camera package.
The ProArm design of telescopic carbon fiber support arms boosts the GS payload from 30 to 40 pounds. The ProArms telescope from 24” to 37”, generating a boom range of 55”, allowing for smooth sweeping movements and increased precision during your shots. . Additionally, the ProArms feature 1/4"-20 and 3/8"-16 threads that allow you to mount monitors to either arm to keep it in your line of sight.)
* Optional Air bladder/cushion for Lumbar Support Upgrade to assist your lower back comfort, is included.
* 2 x DJI Ronin 2 Quick Connect for Ready Rig
(* = Optional parts included in this package are over US$4600.00 value)
