Forza 500 (500w LED) vs. Profoto 1200w HMI
Mark K.
Melbourne, Australia
Hey gents,
So I tested the Forza 500 up against my Profoto 1200w HMI today, and figured some of you might be interested in the results.
Long-story short? I was sadly underwhelmed by the output of the Forza.
Colour-wise the Forza was very impressive. Effectively equivalent to the HMI bulb according to my spectrometer. And the beam from the LED is remarkably even too (evidently a COB has significant advantages over an open-faced point-source light in this regard)
Output-wise however, there's clearly still no replacement for displacement. At 800 ISO and somewhere around 4-5 meters away from the lights (I didn't measure the distance, as I was only interested in comparative output), using a 50 degree Profoto Magnum reflector on the HMI (focussed to an evenly-spread beam), and the Forza's slightly tighter-beamed standard reflector, the numbers came in at:
- Profoto 1200w HMI: f/11 + 2/10
- Forza 500w LED: f/5.6 + 8/10
So approximately a 1.5 stop advantage to the HMI (that's three times more output - you'd need three Forza 500s to match the output of the 1200w Profoto)
Pairing the Forza up with it's Fresnel attachment (which works well, and has a pretty remarkable 45-10 degree range) I got:
- Forza 500w LED @ 45 degrees: f/5.6 + 1/2
- Forza 500w LED @ 20 degrees: f/8 + 6/10
- Forza 500w LED @ 10 degrees: f/11 + 1/2
Zooming the Magnum reflector on the Profoto in to create it's most intense hotspot (the hotspot being about twice the width of the Forza at 10 degrees - but the outer edges of the beam still spreading close to 50 degrees overall) I got:
- Profoto 1200w HMI: f/22 + 8/10
That's just a hair shy of f/32 (and with broad-beam reflector). With a tighter reflector that didn't lose as many lumens to the broader surrounding beam/spill those numbers would go up even higher.
Which suggests to me that these higher-output COB LEDs are basically still on par with HMI on a lumens-per-watt basis. Now if we were comparing to an HMI fresnel, we'd lose around a stop to the lens, and there'd be less in it (maybe only half a stop). But compared to any open-face HMI (bug-lights like the K5600 Jokers or this Profoto of mine, or any Arrimax HMI like the M18) there's still a massive difference in output.
I was kinda hoping there wouldn't be, so I could pick up the Forza 500 or the Aputure 600 and have all the output delights of the smaller HMIs, without the all bulb-blowing/5-minute warm-up times/and the joys of proper colour-shiftless dimming. But I fear we'll be waiting some time yet before we get there.
I think that the Profoto Magnum dish that you are using with the light is probably making the light brighter than the Forza 500. The Magnum looks to be very close to "parabolic" and because it is larger it is brighter. The design of the light, with its bulb sticking out (like Joker bug lights) makes for very efficient reflecting properties with the reflecting dish. This guy did a review of the Forza 500 and he shows that in certain configurations the Forza 500 is brighter than a 1200 hmi.
https://www.youtube.com/watch?v=7fJHOIWTETk
Looks like Locky's tests (which are much more comprehensive than mine) basically match my results exactly. With a bare bulb, the 1.2k HMI is giving triple the light output. But plonk a lens in front of the HMI and they end up about the same.
Hey mark, how do you like the profoto for an hmi unit? I’ve heard they can be loud on set and problematic for audio? Seems like great units to utilize profoto modifiers. Also the dimming ability, but I’ve never used one..
How is the fan noise in Forza 500 when doing interviews in small spaces?
