Miguel Lindenberg
New member
- Sep 16, 2008
- Age
- 44
Hello fellow AC's,
I'm working on a long feature film with the Red cam and COOKE s4 lenses.
We've been checking the cam back focus every once and then, without difficulties on doing fine adjusts on it. (Puting a 14, 18 or 25mm on and on the minimal distance, 25cm.)
Unfotunately, today something weird came up:
All the lenses, from 14 to 135mm, are good on their minimal distances.
But as we put then farther, 2 meters on from the chart, they all start having serious differences from their supposed ring distances. 10 to 25 cm differences on 2 meters and a lot more as we went farther from the chart like on 7 meters:
65mm - 8mts 75mm - 8mts 50mm - 8mts 40mm - 8,5mts 35mm - 12mts !!!
The biggest mistery is that the 100mm and 135mm are sharp on all distances, what excludes the back focus problem hypothesis.
The first thing that comes up to my mind is to get a second camera body (35mm that should be pre tested and reliable) and test the lenses on it. After that, be sure what lenses are reliable and with one them adjust the RED back focus,
Do any of you have had a similar problem working with the Red before or have clues on how should we proceed?
Facing the given results is really hard imagine an explanation to this problem.
Thanks in advance.
Thanks in advance.
