Fixing dark light in post
Paco Bech
Hello,
I have shoot this with a Red One MX, as you see is a concertin a theater and the lights are. Is there anyway to bring a little light to this without being too overexpose? I mean to give some color and light to everything that is not black, except the stage area. I dont have real experiencie, what program should I use, what would be the process if ispossible to fix this a bit?
Uploaded with ImageShack.us
Get out your power windows. There is likely some heavy grain hiding in the shadows, you'll only be able to go so far. Sounds like you're starting out so I imagine you have Apple Color available. Load the in camera proxy into FCP on a timeline, send to Color. Set up your RED RAW tab setting first then use secondaries with a feathered oval vignette or custom shape. Effect outside the shape and carefully gain it up. Apply additional corrections as needed.
Thanks so much, yes, I have no experience. Sorry, what you mean by power windows?
I just wan to give a little more light in general, so let´s see if I can achieve a decent result
I have Apple color, a friend with little experience told me DaVinci is a better option than color, would you recommend DV over color?
Best regards
