David Chan
New member
- Feb 16, 2011
This has nothing to do with Red cameras but does anyone ever have the problem of exporting a video that plays perfectly well on Final Cut only to have the exported file flash to a green background multiple times, jump around and lag in image? Usually happens when there are added effects of some kind on the time line. It plays fine on Final Cut playback but screws up after you export it.
Sometimes this even happens with Final Cut playbacks where a random frame appears in the playback but is not actually there when you play it frame by frame.
I thought it was a rendering problem of some sort but the sequence has already been as fully rendered as possible, and still these random frames appear either in the playback or exported video.
Is there an easy solution to solve this? Coz it's mighty annoying to be stuck on something that should've been done in 5 minutes.
Any help would be appreciated.
