Nick Morrison
- Nov 9, 2011
- Brooklyn
- www.smallgiant.tv
Hey guys, I'd love some input and feedback on the best way to approach filtration on narrative shoots...where you may often be shooting Multicam with 2 or 3 cameras. How do you stagger the filtration strengths across the focal lengths?
For example, with DIFFUSION (say Classic Soft) I've heard that wider focal lengths (21mm, 25mm) will generally get stronger diffusion than telephotos (85mm, 100mm). Is there a rule of thumb to go by? Or do you judge by eye? But I've also heard if you are using an 85mm or 100mm for portrait work, for a CU, then you can leave the diffusion THE SAME as on the wide, or maybe make it stronger! What do you guys think?
How about COLORED FILTERS? I've heard that you should keep all focal lengths the SAME, as this is a color shift and you'l want to keep this uniform.
How about FOG FILTERS like Smoque? If you are using Smoque 1, do you just leave it on all the focal lengths and call it a day, or are you actually adding a Smoque 2 on the wide?
And how about BLACK PRO MIST. Do you treat that like Classic Soft? Make the wides stronger, and longer focal lengths weaker? (Except again if you are on a CU then you judge by eye). Or because this affects the blacks do you treat it more like a color filter and keep all focal lengths uniform.
I need some help figuring this stuff out. I'm totally confused. Thanks.
