Hi guys. I've been on DVXuser for a little bit now, and I have been posting about this project of mine. Someone at DVXuser suggested that I post this here also. I just don't know why it never occured to me. But here it is.
Ok Guys,
So after 9-12 months of trying to put this thing together and being ignored, stalled, and manhandled by the LCD industry, I'm finally proud to mention that I've pretty much finished my LCD. (really wished I would have been able to get this thing out sooner)
Here are the specs.
LCD Panel:
Features:
High resolution
Ultra-wide viewing angle
High contrast
Wide color gamut
LVDS interface
General Specifications:
Display area........................170.5mm (6.69") W x 127.9mm (5.06")
Diagonal Size .....................213mm (8.4")
Display Color.......................16,777,213 colors
Pixels..................................1024 (h) x 786 (v)
Contrast ratio......................500:1 (typ.)
Viewing Angle......................Horizontal 85°R, 85°L. Vertical 85°T, 85°D.
Polarizer Surface.............Antiglare
Luminance.....................350 cd/m²
(this is the panel with the regular inverter. I have a more powerful inverter, but no way of testing the actual brightness. Its definitely higher than 350 though)
Backlight........................Edge light type: 4 cold cathode fluo.
Controller Board:
Power....................................12v
Video Inputs..........................ARGB, DVI-D, Composite Video, S-Video, HD-Component (YPbPr), HD-SDI (optional w/1 or 2 channels)
HD-COMPONENT PORT :
Mode Resolution
480p/60 720x483
576p/50 720x576
720p/60 1280x720
720p/23.89 1280x720
720p/24 1280x720
720p/25 1280x720
720p/29.97 1280x720
720p/30 1280x720
1035i/30 1920x1035
1080i/50 1920x1080
1080i/50 1920x1080
1080i/29 1920x1080
1080i/30 1920x1080
1080p/25 1920x1080
1080p/30 1920x1080
COMPOSITE, S-VIDEO
System Resolution
NTSC 720x480
NTSC 4.43 720x480
PAL 720x576
PAL M 720x576
SECAM 720x576
Picture in Picture
Flip Horizontal, Flip Vertical, Rotate
Picture: Brightness, Contrast, Saturation, Hue, Sharpness
Aspect Size: 4:3, 16:9, 16:10, 2.35:1, 2:1, 1:1
Custom sizing: Under-scan, Normal, Custom (you kind of can zoom in on w/ this setting)
Blue Only (not sure if you can calibrate with this option, but its in the menu)
Auto Picture, Auto Color (I set my bars from the camera and this calibrate the monitor pretty well. Really like this feature)
Gama: 1.0/1.6/2.2
OSD: position and time to remain on screen, transparency (for menu)
Color temperatures: 5000k, 6500k, 8000k, 9300k, User
Monochrome Mode: color, red mono, green mono, blue mono.
Physical Box: (revision: almost forgot to post this)
size ......................8.5" wide x 6.625" tall x 2.5" deep
weight...................3.2 lbs with the (1) HD-SDI option
The good thing about this is the image. Its really superb. The next best thing is the Angle of viewing. I really haven't seen anything with that much angle of view. Which is good for when more than one person are relying on the LCD.
Here are the first pictures. Please comment and ask questions if you would like.
Note the RGB connectors on top will be BNC and not RCA as those shown. I will fix this. I also need to add stickers to label things or possible do silk screened white letters.
Thank you.
Luis Sinibaldi
