Hans von Sonntag
Blue channel. Of course!
Hans
Hans
So, just for fun I applied my GIO LUT (see https://manifoldrecording.com/2017/12/20/gio_lut/) to your image. I set the ISO and WB to the "native" values (800 and 5600K) and then compared the results of the GIO_Max and GIO_Min functions. GIO_Max gives a GIO Scope reading on the maximum of the R, G, B channels and GIO_Min gives the reading based on the minimums. You can see just how wildly different are the brightest channels from the blue channel this way.
Max 1/2 @ 100%:
Min 1/2 @ 100%:
Max 1/2 @ 50%:
Min 1/2 @ 50%:
If you watch the clip in the max view, you see little noise. If you watch the clip in the min view, you see lots of noise. As others have said, a low K white balance means the blue channel is being amplified a lot, so you need to expose with a very low ISO (250-320) to give it a chance.
