Gunleik Groven
REDuser Sponsor
Not to practical three months later in a DI.
battistella
Could be...
Bt it is a good point to marks point that we want the "metering" from the RAW view in the exposure tools, not the image...
battistella
You know what is weird.
Since the very first day of owning a red (early adopter 758) and right up until today, the only place to see RAW view is in the camera.
You can not see raw view (or the specific RAW view lut) on anything other than the camera or camera monitoring devices. That means a DP uses that image as a reference image and will never have the chance to his reference image it again.
so maybe that needs to change, maybe it doesn't .
discuss...
battistella
There should be a view (LOG, RAW, PRO VIEW, B&W whatever) separate from the look placed on a monitoring path that allows a person who understands the tools, the DP, gaffers, operators, etc. which allows you to see "into the negative" a bit better on set.
Battistella
Could be...
Bt it is a good point to marks point that we want the "metering" from the RAW view in the exposure tools, not the image...![]()
Yes it is my understanding that the analogy applies. Each line of chip (M, MX, Dragon) has it's own response curve that defines it just as each film stock has it's own defining response curve.
You do not actually change the sensitivity of a film stock either. When I set the ISO on my old film Pentax, what I am doing is changing the way the internal light meter responds. My understanding is that this is the same with Red. The difference is that the ISO setting can also directly effect the way the captured values are displayed, which does not happen with film.
Am I still on track?
In using film, the DP is the person responsible for how the light hits the film plane, the best ones actually work in blindness with their knowledge of how the film and processing would react. They had a shit BW video tap but made great images. Why should that knowledge or method deviate too much because of an HD monitor onset! which represents about 1/6 of the data being captured.
Battistella
So ... what exactly do you want to see in this "LOG, RAW, PRO VIEW, B&W whatever" - and tell me EXACTLY how you want use it and why.
That knowledge and method does not deviate at all.
Yes you are on track. But I'd modify a couple of these observations. The ISO setting on your Pentax changes the way your light meter responds, that's true. But it's important because it changes that way you will expose the film. And it very much changes that way the captured values are displayed (though not until after developing and printing).
To quote myself from another thread: After some detours, I've come to think about exposure on Red in much the same way that I used to think about it on film. A film has a fixed sensitivity (ISO), but knowing that, I can choose to expose at a different ISO and push or pull in post (either chemically or in transfer or printing). I know the image will have different characteristics if I do that, and that's part of my exposure calculation. I can over expose and under-develop, and get more highlight compression and more shadow detail. I can under expose and overdevelop and get more contrast, more grain, but with the risk of blocked highlights. All from the same film stock.
I expose Red with very similar thinking, and that's where ISO has become important again -- not the camera's ISO setting, but ISO as a reference for light levels in front of the lens. I know that the sensor is about 320 ISO native, but I don't love the completely-clean image I get at 320 for most things. At 800, I get a bit of very pleasant noise, which I like, and the added benefit of some headroom that lets me roll the highlights off nicely. But for things like tabletop and package shots, I usually want a "fatter negative" with more color and a bit less noise, so I expose for 640 or 500, knowing I have to watch the highlights more carefully, but knowing that it will do things to the image that I want. Or as with Gunleik's image above, I can underexpose and get an image where darks cluster together and mix with noise a bit, and the hilights occupy most of the long slope of the tonal curve. All with a sensor that has a fixed response.
What I can't do is expect that a scene I "shoot at ISO 400" will look like a scene that I "shoot at ISO 3200". That won't happen. (And it won't happen with any other camera on the market either, by the way.) Light matters.
I want a flat logish style image shows me something more complete than linear light. RAW as it is or RC4/REDlog film would be perfect.
Only way to do this is false color meters - just like being discussed in Truth ... or False Color thread. This can not be indicted accurately enough by a single RGB representation alone.I want to see this so I have a sense of the total frame and I can later decide what I have in the blacks and the highlights so that I can adjust later in the grade, know what is blown out and what can not be recovered.
I want the brightness of that image to be as close to the best possible image the camera can produce (sensor native 5000K, baseline ISO accurate to metered light, noiseless image) that yields the sharpest image with the best color fidelity and the widest latitude, without coloring it up for me. (If I want to deviate from that I will do my own testing and cook my own look, but as a start I want to know what the manufacture thinks will make the camera/film stock shine in terms of optimum technical precision, by adding a simple s-curve to make one lights easy.
You can do this now - just uncheck "tools" in the monitor setup. You gotta go one HDMI and one HDSDI - but you can convert HDMI to HDSDI with those bad ass small ATMOS converters.I want two monitoring paths, the professional one as above with menus, guides etc and a clean cooked look for clients.
I want histogram, goal posts and Exposure tools. No ire, no zebra or any of that crap leftover from shitty video cameras.
battistella
this goes to my point of RED taking a leadership position as the replacement of digital film. I feel they should be on this like a pit bull on a bone. Needs to be established right now, with this sensor and this system. Put the eggs in that basket.
You hear me on that one RED.
battistella
I'm going to copy and paste this into my reference notes because it spells out a plan of action that I might use... assuming these same numbers correlate to Dragon
How much for the goose Wonka
This is a pretty flawed request IMO because " best possible image" and " best color fidelity", etc. are SUBJECTIVE. You would need to articulate technically what you want to see - in technical terms - not subjective.
Well ... in all honesty David - most experienced cinematographers understand ISO on the RED, Alexa, F65, etc. and have no real issue with exposing on the sensor(s) and system.
I think it IS established with the sensor and system.
I just think there is a lot of confusion over ISO with folks who don't understand the basics - which is okay - it can and will be confusing if you never really understood the basics - but this forum exists, right? Reducation exists, right?
A lot of confusion comes from the fact that Red has these three different customer sets: people who learned on film, with its fixed ISO per film stock and workflow that includes post-processing; people who come from video, where ISO has no meaning at all, there is just gain; and the DSLR group, for whom ISO is a baked-in gain-with-noise-reduction setting. They all understand ISO differently, and I think we often talk past each other because we don't understand the terms in the same way.
As as I stated, the same way kodak or Fuji provides an Asa value, for their film with a sticker on it that says 500asa daylight, they are telling us that with daylight sources at meters set to 500asa and exposing this film in that way and processing it with the correct chemistry will yield a correctly balanced image and in this way the stock will perform at or near its optimum.
Thats for for the beginer, it's a baseline.
The he expert says ok. What if I make this 2 stops over, cross process push, pull and find their own style and method.
But it a baseline exists.
In a sense red is handing us the dragon and saying (quoting Phil) the Asa rating of this film is 250-2000 rate it however you like. I just think the manufacturer of the sensor (like film) should determine through their own internal testing the baseline for the novice user. Like, here, 5600k sources, 640 Asa and set aperture and shutter accordingly and you'll get decent relatively noise free images.
Battistella
