Gregor Hagey
but where do you set your t-stop?
It's important to test, test, test so you can confidently set your iris though. The ISO might be just metadata but you can't change your mind later about the T-Stop!
One confusing aspect of shooting/metering at ISO 320 is that a middle grey card actually reads at 40% on the waveform instead of 50%. You need to overexpose the card by 2/3 stop to get it to 50%.
I think the most important thing to understand though is that it's not important to get middle grey or skin tone in the right place, just expose as bright as you can without clipping white. This means each scene needs to be evaluated holistically. A simple and easy tool for this is the histogram. A lit white object should have a slope at the right of your histogram not a straight line. If you are monitoring at ISO 320 you can trust that when the histogram is clipping the sensor is clipping too. First the blue channel, then green and finally the red channel will clip. Of course don't let specular highlights throw you off (they will clip no matter what you do). Dulling spray and polarizers are the best way to deal with them or power window a blur effect on them in post.
When the .r3d's are processed you can darken your picture at this stage to set the mood you want. This is where prep is important so you can create Red Alert or Redcine presets(LUTs) so the digital lab processing the .r3ds knows what your intentions are.
Of course a meter is still indispensable for balancing lights. Also, you should stick to one exposure level for a scene or your grain/noise could change with each shot.
