EVF Bomb + RED monitor
Julian Chojnacki
New member
Nashville, TN
I'm using the Wooden cable connected to the side and the standard Raven monitor on the top. Is it possible to have all the info in the monitor also visible in the EVF bomb?
I am sure you can. Have you check in the monitor settings?
Menu > Monitoring > Monitors > (Should be EVF Left)
Somewhere in there? Make the x in the box for Tools?
I have a pretty new firmware version and it does change, the setting path might be different to you.
