Epic-w loosing Touchscreen signal when HDMI plugged into base expander
Tim Daust
Atlanta, GA
This is probably user error here but need some help. I'm on set right now with 2 epic w on a shoot, 2nd day, all day yesterday we had problems with my epic w not being able to output a feed to both the LCD touch screen (connected via side pogo) and the HDMI out from the base expander (tried vmount and normal base expander)
do the side pogo on the brain and the hdmi output from the base expander share the same "output" ???
works completely fine if I use the top pogo to connect the LCD instead of the side one.
*edit* running latest firmware from 10.11.16 and already did factory reset as well
Yes, they share the same output
Copy, thank you for a quick response. I rarely use hdmi, rather use sdi personally.. But client gets whatever they want. :)
