Audy Erel
- Nov 27, 2016
- Jakarta-Bandung, Indonesia (Bali)
Gemini highlight retention test please
Yes I agree, there is much more information there. The difference is even bigger when you look at the JPGs on a big screen.A HUGE thing as well, that if the fill lighting is exactly the same, the Gemini isn't just 'cleaner' with noise structure, but it's also getting INFORMATION that's not there on helium and Dragon. Look at Dragon and Helium, and it's just black, with noise on top, where Gemini has clear shape and skin-tone coming out of that. Even at 6400, the mustache is a clear example of more detail, even though it's less resolution.
Seriously impressive.
I did a crop of the jpegs at 6400 and 12800 ISO. I'm focusing mainly on high iso situation since for us this would open up a lot of situations.
Hope you are ok with me uploading it Martin since it is of course your test
I recommend downloading all of the jpegs from Martin and go back and forward on a UHD TV. Our OLED TV show the differences in noise much clearer than our computer monitors.
From what I can see in this test, these are my conclusions:
- I would not use Helium higher than 3200 in this situation which is still impressive.
- Gemini seems usable all the way up to 12800 if you can do strong noise reduction, for example if the topic does not have a lot of detail.
If I compare Helium downsampled to UHD noise with Gemini I would say that Helium 3200 is a little bit cleaner than Gemini at 12800. That is indicating to me that downsampled to UHD Gemini is about 1 2/3 stop better than Helium. Possibly you could do more clever noise reduction on Helium since the resolution is higher.
If you would watch Helium at 100% and Gemini at 100% I would expect Gemini to be even better, maybe even more than 2 stop better.
Considering how good Helium already is when it is dark, Gemini is a big step forward in this regard.
Best wishes,
Andreas
Maybe because Dragon looks more under exposed compared to Gemini. Just the LL Gemini advantage..Is that DSMC1 Dragon footage? My Weapon MG Dragon looks cleaner than this. Plus what OLPF?
Yes DSMC 1. Also are you comparing to yours based on new or old ISO calibration?
As Graeme explained to me, the circuitry in DSMC2 bodies create much cleaner images than DSMC1. Also, switching to LLO filter helps a lot too.
I did not notice - but was any of the cross camera exposure footage shot with Gemini not in 'LL' mode? So 800 would be way overexposed in LL mode, right? And no ND were used in any of the tests? The bulb was on a dimmer to show saturation of highlights?
For Helium, I have noticed it gets dramatically cleaner when downsampled from 8k to 4k. To the point that you can't compare 8k to 5k and get same answer as 4k post of each.
Does the demo compare 1:1 with same framing? If so what was downsample algorithm?
Thanks for the timing of this test BTW.
800 ISO in standard mode, 1600-12800 in LL mode.
400% is relative to the UHD timeline. I did this to help ensure viewers can judge the noise pattern regardless of online compression. All the reds were shot with the standard OLPF. 1.35 was the FLUT value to align the chart.
SETUP
Camera w/ 50mm Ultra Prime (T Stop matching Key Light) @ 56000k
Key: Astra 1x1 w/ Snap Bag into a 4x4 Half soft Frost @ Minimal output - 5600K
Room Fill: Skypanel bounced off ceiling @ 1% - 5600K
Practical Bulb: 80% on Dimmer - 3200K
Standard and lowlight are very similar in exposure. I think standard OLPF makes lowlight obsolete.
Is that true. I thought there would be more difference with the lowlight? Has anyone measure the difference in light?
Andreas
I would have though the 'light' is the same but the noise characteristics and range would be different. So 800 at LL and Standard would look initially similar, except the LL would perhaps have less highlight. Just guessing based on what's been said though.
It would be a good test
cheers
Paul
Hiya Paul. Just to be clear I talk about the Low light OLPF (and not the LL mode in the camera). As you probably know the OLPF blocks or reflects certain amount of wave lengths to various degrees so you do actually have less light hitting the sensor.I would have though the 'light' is the same but the noise characteristics and range would be different. So 800 at LL and Standard would look initially similar, except the LL would perhaps have less highlight.
