Epic-W FOV on 2k.... shooting High speed... situation.
Minu Park
Seoul, South Korea
www.caveman.co.kr
Hmm...
4.81x
It's like If I put super wide 10mm will be most likely 48mm
A bit frustrating on shooting on super slow mo.
I am already looking for widest lens that I can put... in case I need super slow mo.
After researching on ebay.
Only option is C mount lenses that are go down to 1.8mm - 6.7 mm (6.7mm in 2k windowed mode in Helium sensor is about similar to 22mm on Super 35mm sensor)
Yes, it seems we might have an option. But I am very negative on this answer.
1. Does C mount lens's sharpness good enough to shoot on 2K?
2. Does C mount lens could create similar tone and color rendition as any cinema lenses that are out there to match?
3. According to one seller on ebay, who sells C mount to PL adaptors, he has stated that "There is some risk that the C mount lens could hit your sensor"
In summary:
If you want super slow mo (more than 200fps), you might want to stay in Dragon sensor. As of it's in this current situation, I don't think I can find C mount wide angle lens that can be similar quality as Super 35mm lenses, and it's look. As Jason and Nick discussed, dragon sensor's case, one single wide zoom lens that could figure out most of the problems shooting on 2k situation.
Ideally, it would be really great, some how the Red Team could revolutionized a new "Pixel binning" system into our cameras. But that's just a hope.
there are a ton of different c-mount lenses... Calkovsky Camera has a ton of 16mm and c-mount lenses.
also a bunch of PL Mount super16 lenses, like this, this, this
Zeiss did make the Digi-Primes and Digi-Zooms and they are supposed to be some of the sharpest lens made, but are b4 mount and the image circle are super small. But, at that point you could be using Fujinon lenses, which are comparable...
in principal these lenses are sharper than the full frame lenses.
