Epic Low Light Sensitivity
1.5 stops! Thank you so very much for the info!!
So let me see if I can get this straight with my limited technical knowledge:
1.5 stops lower noise would mean that we'd go from ISO 320 to ISO 800 correct? Also it would mean that we could stop down from f/3.3 to f/5.6 and still use the same amount of light that would be necessary for a Red One with equal DoF, right?
I wish I could find the post where David Mullen answered this question, but since I can't, could someone please tell me the approximate stop down necessary to get the same DoF you get with 4k when you want to shoot 5k?
.....could someone please tell me the approximate stop down necessary to get the same DoF you get with 4k when you want to shoot 5k?
I’ve based my examples on CoC of 0.2mm (5 lines pair/mm at 250mm).....'a' limit of normal human perception.
Note it's below the limits of other Coc effects. Also you're mainly interested in sensor size (diagonals) not resolutions as Coc's is a radial effect unless constricted by other properties.
But comparing the R1 sensor horizontal (24.4mm) to the Epic X sensor horizontal (30mm), the CoC's calculations become…...
RedOne
250mm /24.4mm = 10.25
0.2mm /10.25 = .019 (CoC)
Epic X
250mm /30mm = 8.33
0.2mm /8.33 = .024 (CoC)
Epic FF35
250mm /36mm = 6.94
0.2mm /6.94 = .029 (CoC)
So maintaining the same DOF/FOVs, the equations (don't forget lens crop factor 0.8) are……
R1/50mm/f5.6 / 2.0 metres = .343m (depth of field)
EpicX/62mm/f6.8 / 2.0 metres = .343m (depth of field)
Epic FF35/74mm/f8 / 2.0 metres = .341m (depth of field)
f5.6 to f6.8 gives a 1/2 stop reduction (from RedOne) due to Epic X sensor size increase.
I'm not sure if 1.5 stops of noise equates to an increase of 1.5 'usable' stops of dynamic range in the Epic X, but compared to the R1 you may have another stop which is kinda what Red announced last year they would achieve with the Epic s35, although they probably meant 1 absolute stop not considering maintenance of DOF. The biggie is will they achieve another 2 stops with the FF35!
Dave
lol...... yes I am.
The answer after all that junk is you now have another 1 stop over the R1 (for the same DOF experience!)
Dave,
Dave,
:arf: Are you fucking shitting me?! So pulling focus can be the same as on a Red One, only with higher resolution, wider filed of view at equal focal lengths, and you only need half the light?!?!
Am I understating this correctly?? Cause if that is in fact the case, boy o boy... wow...
lol...... yes I am.
BTW, I am glad to bring laughter to ya. :thumbsup:
Most of what you said is correct, except for FOV......it stays the same if you choose a slightly longer (x1.25) lens. And yes, on a larger sensor with same size pixels, you will get higher resolution. In this scenario, if the Epic X sensor is 1.5 stops faster than the RedOne's sensor and you lose 1/2 stop due to maintaining DOF on a larger sensor, then the result is you have 1 extra stop to play with.
D
Well, yes, if you chose a slightly longer lens you will get the same, but if you put an 18mm on a Red One and then you put it on an Epic-X shooting 5k you get a wider FOV than on the R1.
@Jim: If I understand this right, then with 1,5 more sensitivity on the sensor it could also mean 1,5 more on the dynamic range. Can you confirm or disproof that Jim?
They are related, but not all the same.
Engineering DR is defined as signal/noise. So technically DR has increased. DR is also defined as the difference between, or ratio, of the lightest and darkest elements on a printed or displayed image. Close, but not exactly the same.
Sensitivity can be discussed as native sensitivity or useable sensitivity. If you are completely happy with the noise level at ISO 800 of a sensor with a native sensitivity (optimum) of ISO 200, compared to a sensor with native sensitivity of ISO 200 but only yields acceptable noise results to ISO 400, is the 1st one more sensitive? Technically no. Practically yes.
The common ingredient in the discussion is noise. Lower the inherent noise level of a sensor (as we have done with Mysterium-X) and you can push it further with better results.
Additionally, some companies have gotten pretty good at NR inside the DSP. That is not the same as inherently less noise from the sensor. You pay a price for noise reduction after the sensor.
Jim
Jim
I wonder if thats part of the reason I find 5dmk ii footage so "plasticy." It all looks like its been run through some rather strong noise reduction software. I guess it could be just the compression on the image though, I don't know.
Im beyond excited for these new Red sensors. The improvements that came with build 20 have already scrambled my eggs, i you will. I cant even imagine what the future holds.
noise reduction
noise reduction
Jim
To simplify things noise reduction is just "chopping off" certain frequencies(in the upper range) where the noise usually "resides"
Ufortunately these are usually the same or (or close to) frequencies that contain the finer detail of the image (resolution)
So, generally speaking, the price for noise reduction is resolution and the skill is to find the proper balance when the image is relatively noise free and resolution loss minimal. This is where the individual taste interferes, unfortunately....
... I quite can't understand why some manufactures have noise reduction within the camera instead of leaving it into post. Of course, for immediate viewing purposes NR is ok as long as it is not hardwired to the data file.
It's bit surprising that camera manufactures still employ ISO settings in digital cameras. For, that's all history now. Consequently, for me it would make more sense to have just raw metering showing when one hits the right end and then for viewing one could adjust stops, such as -1 1/3, +2 2/3 etc. telling the difference between sensor exposure and viewing. In low light conditions this gave immediately an idea how many stops (or bits) from the maximum dynamics (bit depth, resp.) are lost. The point is, the camera should encourage the user for the best practice --shoot to the right-- resulting in the maximum image quality.
