[FS: GEAR] Easyrig Vario 5 with Cinema 3 Vest and 5" Extended Arm (Mint Condition)
David Jaure
Miami, Florida
-Used it only 4 times…
SELLNG PRICE $3,600 (US Dollars)
The*Easyrig Vario 5 with Cinema 3 Vest and 5" Extended Arm*is a body-worn support system that is adjustable to support camera rigs weighing 11 to 38 lb. The system works by using a suspension line to support the weight of the gimbal rig, taking the load off your shoulder, neck, and arm muscles, and distributing it across your torso. The tension line is adjustable by turning a screw in the back, letting you dial in the appropriate amount of tension for your rig. The system consists of the Cinema 3 double shoulder vest, a Vario 5 standard support bar, and a 5" extended support arm. A carrying bag is also included for convenient storage and transport of the Easyrig system.
Features
* 11 to 38 lb load capacity
* Adjustable line tension for different cameras and configurations
* Lockable camera hook
* Vest and waist belt made of breathable material
* Made in Sweden
If you have any questions, please send a private message
david at 313-films dot com
