Jordan Livingston
Today I began field testing my newly-added 2nd REDRocket. This is also the first time I've tested with REDCINE-X Pro.
It seems that both Rockets are recognized by my system. They both show up in the System Profiler, as well as in REDCINE-X Pro. However, whenever I enable the "second" Rocket (either by itself, OR alongside the first one), the Rocket ceases to function.
In other words, Rocket # 1 functions as expected. Rocket #2 doesn't function at all. And Rockets #1 and #2 together don't function at all either.
What do I mean? Well, no image in the viewer, and transcodes report errors on every frame.
Again, both the System Profile AND REDCINE-X PRO are correctly detecting the presence of the two Rockets. What could be preventing Rocket # 2 from functioning?
UPDATE: I just tested this with REDCINE-X Build 501 (64-bit) and found the same behavior to be true as with REDCINE-X PRO. So it does not appear to the software. Also, I'm using the very latest versions of the REDRocket drivers and firmware.
- Jordan
- Jordan
