Clayton Taylor
Question - if you're using the DSMC2 outrigger handle on your new Raven / Scarlet-W, would you need to get the LEMO adapters in order for your 4.7" touch monitor to work? I may be missing something, but from what I can tell, the outrigger handle (and DSMC2 top handle) plug into the same ports that the monitor would plug into. Am I wrong? Should I go ahead and plan for buying the adapters and cable?
Thanks!
Thanks!
