DSMC2 Dual Battery Vmount options?
Bit of a hack but once the new wooden camera dbox is out you could have a second vmount plate on camera plugged into the WC dbox since it'll hot swap between the cableless battery plate and the port
There's also this:
https://www.bhphotovideo.com/c/product/359201-REG/Switronix_GP_TS_GPTS_V_Mount_Hot_Swap.html
You can also add an extra V-Mount plate on the back of your cam with rails, and cable that in.
If you add a slim Hypercore on your cable-less V-Mount plate, you could make THAT your backup battery you hotswap off of.
best
Thanks for trading ideas with me. I think the dual v-mount plate is the best option simply because I can do hotswaps and also keep the camera powered on for longer periods of time when I'm doing doc work.
gracias
