Michael Lindsay
- Apr 25, 2007
- London UK
- www.16ozfilm.com
You beat me to it, Brandon! Yes, v6.2.51 is the one you want, folks.
EDIT: In this version, where available, will show voltage of battery on power up. That voltage meter is not lowering real time with usage so to see actual power remaining, you will have to rely on battery itself or a reboot. Our engineers wanted to roll this release out as is and are aware of the ask to have meter be real-time...
Hi Brent
Quick Q:
is this release for batteries that simply don't work at all?
This doesn't look like it is for us but we are also having tricky battery problems.
Our setup is Pag link batteries which do communicate perfectly with an epic but when using our weapons have an intermittent fault that means they occasionally jump from an accurate percentage to 0% which initiates a shutdown. This is difficult to replicate but happens with multiple cameras and v-lock plates. Also as suddenly as it happens it can go back to being correct and therefore go back to an accurate readout. It is as often as not it flicks back to correct but you can not depend on it.
Thanks Michael
Ps Interestingly when it happens the camera bumps itself off the wifi...
