[FS: RED Gear] DSMC2 4.7" RED TOUCH LCD MONITOR
Trent Watts
Active member
Brooklyn, NY
I've used this monitor on about 20-30 shoot days, and I'm selling it because I bought the 7" touch to replace it. I'm also including my customized SmallRig sunhood solution, which I fixed up with velcro, and is way quicker and more efficient than the usual sunhood strap solution. I've also velcroed the sides of the monitor, which I'll leave on for you to use. As the SmallRig sunhood is very soft and flexible, and the Red monitor buttons are pretty flat, the sunhood fits right over the buttons and applies no pressure to them. There's also just enough room to slip your fingers in to use the buttons. I've attached pictures so you can see my configuration. I'm asking for $1,300.
