Christopher Murray
UPDATE: Let camera sit overnight, recharged batteries and re-rigged and so far LCD is working fine. Strange indeed and will keep monitoring. I thought maybe it had a back connection, however, I tried a few mounts and re-mounts yesterday and even the side mounting point with the same results. It's working now though so that's what matters to me.
I powered on my Raven for the first time with my DSMC2 4.7" LCD connected. I switched to 4.5K, as it was set to 4k as default. Once I did that, the screen began tearing, (probably coincidence) slowly increasing in real estate on the screen, until the entire bottom half of the screen was black and the top half was loaded with tears and lines, similar to that of fixed noise pattern. I've detached and reattached the monitor, powered off and powered on the camera, and within a minute, the problem creeps back up.
