DSMC1 7 inch Monitor not booting camera
Peter Lightowler
Sydney
www.lightpost.com.au
I have 2 x DSMC 1 monitors, both 7 inch touch.
One works perfectly, the other however won't boot up when the camera is switched on, it gets stuck in initializing mode.
If I plug the good monitor in and boot the camera up, I can switch out the monitors and the dud monitor works perfectly.
Once I switch off and try and reboot the brain, the monitor is stuck initialising.
I wonder if it is a failed firmware update or is it just dead?
Is there any way to force a monitor firmware update or do some kind of factory reset to try and get it to work?
Cheers Pete.
