Robert Berger
- Feb 14, 2007
- Netherlands, Amsterdam
- www.camlight.nl
Fuji Cabrio / Red UPDATE!
Just got off the phone with Manny from Fuji... Here's the deal... and YES, it works! And YES! I'm one happy camper!
You MUST power the lens from another source, not the Epic. That much I knew; I use the 20 pin to AB D-tap...(I want the 20pin to Lemo next!). HOWEVER, the lens must be powered up first, then the camera! So if you swap lenses... you'll unfortunately have to power down first! Bummer, but hey, now the lens data is in all 3 of the Cabrios, (and all the Red Epics/Scarlets) AND you can trigger the record function from the lens! No more having to reach up with your left hand to 'red light' the Epic! So SWEET! Jarred Land, Matt Biederman, Trent Lillehaugen and all the others who worked on this... I apologize for the bombardment over the past 3 years... but damn! You guys made it happen! THANK YOU SO MUCH! Truly!
Oh... one more thing... I almost forgot! You need to TURN OFF the LDS function on the lens, and make it Cooke! (That's dip switch number 2 in the smaller (4 switch) grouping... turn that off or to the left!
If the switch is set properly, the keys mapped in the Red's (it is by default for the "Lens" key mapping feature), and you power the lens first... you get yummy goodness! Thanks Red team!
Hi Curt, until the last time i worked with the 19-90 with my Dragon it shows al info on my lcd but it didn 't worked in Redcine!! Does it work now!! Seeing the changes in distance, iris and focal
New showreel on www.camlight.nl
Best regards
